Re: 3-WAY DIMMER:
2- 3way dimmers will not work properly. You always need a standard switch on one end and a dimmer on the other in this application. It has been that way problably since dimmers were invented.
If you have the first dimmer set to 50% then the second dimmer will only dim that 50% and you will never get full brightness.
[ August 07, 2005, 08:37 AM: Message edited by: bigjohn67 ]
