3 way low voltage dimmer 1000W
Jerseydaze
Ok I did something dumb I need a 3 way low voltage dimmer that fits a toggle plate that can handle 750 watts any suggestions?
get a 1000 watt dimmer...
edit opps missed the low voltage part, is it electronic or magnetic...? you can easily get a 1000 watt magnetic, just not is so many flavors... check out lutrons site...
If you need electronic low voltage you have problems but it can be solved however if it is magnetic low voltage Lutron makes one.
Take a look at the new Lutron Abella line
Lutron Lyneo LX also has them as does many of Lutrons newer styles. I believe the rep told me the Feadra is pretty much a done deal -- seems there was not much interest in it. The are banking on the Lyneo to be the big seller. Of course this is a decora style unit
Looks like some type of euro trash... :grin:
