TwinCitySparky
- Minnesota
OK- I dont work on many signs at all and now have a question with one. I have an 8 lamp T-12 sign that has not worked in years. The owner said he thinks one lamp was lit up about 4 years ago... :roll: I'm thinking the two ballasts need replacing. I've traced power from the photocell thru the disconnect switch on the bottom of the sign. While checking switch, I was surprized to find it is a 3 way (with 3 wires connected) -- I figured I'd find an old single pole instead. Scratching head...
Is this some sort of ballast discharge design for servicing - OR?
Thanks in advance for replies/any additional info.
Man! My supplier sais its a "no go" on the original 4 lamp HO Signa ballasts and suggested rewiring sign with 4 new two lamp units. Internet search finds original Signa units ranging from $120.00 to $350.00 a piece! >>> Yikes!
