The "Carter System". Code violation since the 30's.wrestless said:Can someone tell me what a farmers 3-way is ? Someone ask me today do I know how to wire a farmers three way I didnt have a clue.
We always called this a switch loop. This is the "no neutral at the switch" that home-automation fans disdain.georgestolz said:Real, pull a 14-2 from a receptacle to the light. Pull a 14-2 from the light to the switch. This is what I've been taught as a farmer switch (single pole). Add a switch and some three-wire from that switch, and you have a farmer 3-way.
Why?LarryFine said:Plus, always feed the far switch with the white through switch boxes, and use black and red as travelers.
You devil!georgestolz said:Why?![]()
