bassphisher
What is the easiest and leal way to wire 3 way switches in a residential garage?To be a little more specific this person wants to pull travelers and a neutral in with the feeder( both from the house panel to the garage)to wire a 3 way switch one will be located in the house and the other one will be in the garage.As an inspector the problem that I have with this is when you shut the main breaker in the garage panel off there will still be a hot circuit in the garage.At minimum I don't want circuit from the house panel to be run through the garage panel and I believe that their should be some sort of warning label that warns that the 3 way is still energized when the main breaker(in the garage)is shut off.I would like to hear some other opinions.I am sure that this is a common problem.Thanks
[ September 08, 2005, 10:35 AM: Message edited by: bassphisher ]
