3 way switch circuit to detached garage - run through feeder conduit ? Code violation
Hello, I am new to this forum and am hoping someone may be able to help me out. The question is as follows:
I am in the process of rewiring 1927 built home. I have installed a 200 amp service and ran a 100 amp feeder through conduit to supply a sub panel in the detached garage (about 60ft away). The feeder wire is QTY (3) 3# THWN wires and one #8 to bond the panels together run through 2 inch conduit. However, it is preferred to install a 3 way switch with one switch in the house and the other in the garage. This switch would turn on 4 outdoor lights, 3 located on the detached garage and one on the house.
The plan was to run #12 THWN wires for the 3-way in the same conduit as the feeder. Thus, the #12 wires would run through both panels exit the panels via a 1/2 conduit to an adjacent junction box and then continue the circuit using 12-3 romex. I realize you can't use your panel as a junction box (no terminations or connections will be made in the panel (the wire just runs through it at the conduit openings). I can't find anything in the NEC that makes this incorrect. However, it looks a little funny to me and I am wondering if the inspector with think the same. I really don't want to run a separate conduit just for the 3 way circuit and I have a bunch of #12 THWN in all the right colors just laying around.
Please provide some feedback on the proposed plan.
Thank for your help,
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
