hardworker
I have a 3-way switch controlling a kitchen ceiling fan w/light. There are two switches; one on each side of the kitchen.
At a given time, a particular switch will not send power to the fixture. If you go to the other switch and power the fixture, you can then go back to the non-working switch and it will now work.
The problem will transfer from one switch to the other, but by going to the opposite switch from the non-working, you can always make the switch work.
I have never been able to create the situation to make a switch become non-working. It seems to take place as the fixture is in non-use for a period of time.
I believe the switches are wired correctly, but I have not completely traced the circuit. I thought this was a defective switch, so I replaced one of them. It made no difference.
What would be your interpertation of the problem?
