OK playing with my new EMF/ELF meter I have found huge fields in my mother in laws house, she's 81.
I have tracked them down to the water ground, I get readings of 60 mG next to the wire. Sequentially opening each breaker, I found three problem circuits.
She has an Oxygen concentrator that runs 24/7 providing her with o2, moving that to a different receptacle dropped the readings in half. I plan on running her a dedicated line for this device as well as the two air conditioners she has.
She has two three way circuits in the house, and they are wired old school with only two travelers, and the light pcking up it's neutral from a different circuit from where it's fed.
My question, can anyone recommend a solution that does not involve channeling all the plaster between the two boxes? Does anyone make slave swiches or remote type that will work. Three way operation is desirable and a code requirement here.
Thanks in advance for any help.
