bpascale507
If I have a single switch box, which is wired to be a dead end 3 way (black and red are travelers, bare ground, and white is my power)...is it possible to jump out and add a 120v receptacle? How do I grab a neutral?
al hildenbrand said:Is the neutral present at the other threeway?
If so, convert from a hardwired threeway to an X-10 type, or wireless type, threeway and put the neutral on the white, hot on black and abandon the red.
If the cable from the luminaire(s) is only a two-wire (pure switch loop), then there is no neutral. . . .probably.
