Re: 3 way traveler wires
chasdal,
From the description given,this setup is switching the neutral conductor.That is a bad situation.Why?,normally the (hot) conductor is used and if a problem accures, like the switch gets broken,it will "ground" out and trip the fuse or circuit breaker.By using the EGC as a neutral this will not happen,what will happen is the metal around the switch will be waiting for the first person that is grounded to touch it,that will complete the circuit and in doing so injure that person(to what extent,unknown).
There may be other ways around curing this situation,i.e., check out some of the low voltage switching options available it might cut your labor hours down.
Friends don't let friends switch neutrals!!
frank
