Re: 3 way without a switch leg
well, here is the reason i ask. is that an issue i came across was a 3 gang box w/3 switches, all on the same circuit, its a split house by the way. one 3 way controls the light in the down stairs foyer. that 3g box has the feed going into that box. the travling wires go from the 3g box to the light, in the light there is another set of travling wire going down to the other 3 way controlling this light. in that switch box its the sole set of wires, so its almost acting as a dead end 3 way but the white wire is not commen, the black wire is. In the light box, the red r spiced, the white wire from the single gang is spiced with the black wire coming in from the 3 gang, with the neutral coming from the 3-gang tied to light itself. the black wire from the single gang is also tied to the light. the 3way switch in the 3 gang is wired as a regular 3 way with the neutrals spiced together, the traveling black and reds r on the right terminals and the feed is your common(point). so the light is getting its neutrals but how is get electricity to the light. The 3ways work like the should work.
