davidbananas999
- Minnesota
Ok so the answer to this question is probably obvious.....but I have to ask:
Today at work I wired a garage which requires all receptacles to be GFI'd. The homeowner wanted two switched receptacles on the ceiling so he could plug in a couple LED lights. What I did was run 3-wire out of the switch box to send constant power to a GFCI located below it, black on the line and red on the load, pig-tailed the neutral to two wires, 1 on line and 1 on load, then connected the red wire (in the switch box) to the switch and the neutral to the LED receptacle neutral. My Journeyman was like pft naw bro you cant do that it wont hold. And he's probably right, but we didnt have power to test it out so i just replaced the 3-wire with 2 pieces of 2. I would love to give him proof tomorrow haha.
What do you guys think?
