allenwayne
This is the senario,300 ft from mdp is a undrground feed to a guest cottage.For some reason unknown to me they only ran 3 # 2 al conductors.
The panel is in the kitchen of all places and the clearance is is encroached by counter space,the request was to hook up a package unit a/c.
I was considering bringing the 4 lighting circuits into a 6x6x4 pvc j box out side the building and nippling into a wp breaker box using the 6x6 as a way to extend the circuits into the new panel There is no ground per say and I will sink 2 ground rods ( the area is all sugar sand)The wp panel will have a main breaker so that there is a means of disconnect.
The reason for this is thst a package unit will be replacing one that I wish I had a pic of how it was installed. The panel is within sight of the unit so there goes the disconnect the water heater is inside and I told the customer that I will have to add a disconnect for it.There are only four circuits in the cottage,who ever wired it did install 2 appliance circuits but no gfci devices also told h/o they will be required the 2 remaiing circuits feed bath room l/r and bed room and dining area.Luckily ther dining is on the kistchen circuit so that is a no brainer .I asume I will have to add an afci to the remaining circuit to cover the bed room.I can eliminate the bath from the l/r quite easily and re feed off thel/r from the bedroom afci.
So there wil be 2 SA circuits one feeding the dining area the bath will be seperate and the l/r and bed room will cover the afci issue.
My only problem is that there is wil be a main disconnect at the cottage and since there is only a 3 wire feed from the mdp that the ground rods at the cottage will be okay to satisfy 250
