dielectricunion
- Bloomington IN
I'm getting very confused after running into what I believe to be a totally sketchy and incorrect installation of a subpanel on a residential property.
100 amp subpanel in separate "cabana" feeding mostly in ground pool loads, #2 AL triplex (3 wire) direct buried, grounds and neutrals separated at the subpanel. Electrician says it is grounded because he drove a ground rod.
Is this acceptable? My understanding of the code says no. My understanding of the way electrical systems works says no. I've found several things "online" that say I am wrong, including "ask the electrician".
Ask-the-Electrician | Installing a Sub Panel for a Detached Building
Do I need to run a ground wire for a 200 amp sub panel that is 200 feet away from the main panel? Grounding a Remote Sub Panel at a Detached Building.
ask-the-electrician.com
