Hello, I am new to this forum, have checked it a few times for different questions in the past, and now doing my first post.
I have a customer that has a new piece of machinery that has twin 10 HP motors. The name plate of the equipment states 29.4 FLA. The building voltage is 3-phase with a good 240 to 250 Volts depending on the time of day. The new piece of equipment is only able to be hooked up 480 Volts as per the manufacturer. They are wanting to sell a 30 KVA transformer with the equipment. When I do a calculations on the motor and a 30 KVA transformer, to me it is marginal if it will be adequate for the install.
I figure a 30 KVA will have a FLA of 36.08 (30,000 ÷ 480 ÷1.732) on the secondary side.
Sizing just the fuses on the 29.4 FLA is 51.45 amps, or 60 Amp fuses.
Does anyone have any thoughts on if this 30 KVA will work or do some agree it should be bumped up to a 45 KVA?
Any thoughts on this is greatly appreciated!
