In my classroom I need to convert 240 3 ph. to 208 3 ph. Our school has purchased a 30 kva xfmr (too large) I have 5 labvolt A frames that are going to be dedicated loads (nothing else will be using this xfmr) They will pull no more than 10 Amps a pc. And none of the units will prob. be on at the same time. ALL I have is a 60 Amp disconnect (3 ph.) Do you think it would be ok to feed this xfmr with the 60A disconnect and what size conductors would you use to feed it with?
Thanks
Thanks
