A
a.wayne3@verizon.net
Guest
To those that wire block homes this will be informative,Last year the AHJ`S started requiring us to protect the nm cable where it crosses horizontal furring into truss areas with additional nail plates,so that the ceiling drywall can`t contact the nm in this area when installed ,citing 300.4 D.In addition to the nail plate that protects the NM where it crosses the furring they wanted additional nail plates in the area above the furring,if there was enough room to slide drywall into that area.What a pain but we complied.One nail plate horizontal on the furring and ond on a 45 to protect this area.Personally I saw a potentially hazardous installation.Well my fears turned out to be valid.One of the service crews called me and asked me to come by.The call was when ever the HO touched the SGD frame he got shocked.Long story short,The corner bead was energized as well as the foil backed vapor barrier.After removing the drywall over a 4 gang box I found this additional nail plate had been pressesd into the 14/3 for a Lanai fans constant hot.The nail plate had in turn been energized, the foil faced vapor barrier as well and the corner bead.A 3 year old child had been lit up as a result.I called the chief as well as the area inspector and informed them of what had transpired.For now no more additional nail plates. But I can`t help but think off all the homes that had this type of protection and how many more problems like this will come to bear.
