300.5E
dslx
New member
Coral Springs FL
Cable, Raceways or Boxes Installed in or Under Roof Decking.
Section states: A cable, raceway or box installed in exposed or concealed locations under metal.....
Later in the same section it states: A cable, raceway or box shall not be installed in concealed locations under metal...
Is this not contradictory?
Let me post the whole section with a few highlights. Notice carefully the keywords "under" and "in" used in the bolded statements.
(E) Cables, Raceways, or Boxes Installed in or Under Roof Decking.
A cable, raceway, or box, installed in exposed
metal-corrugated sheet
roof decking
, shall be installed and supported so there is not
less than 38 mm (1 1⁄2in.) measured from the lowest surface of
the roof decking to the top of the cable, raceway, or box.
A cable, raceway, or box shall not be installed in concealed lo-
cations in metal-corrugated, sheet decking–type roof.
