All-in-One devices provide installation labor savings and have been designed specifically for areas where local codes allow main breaker load centers to be mounted outdoors. All-in-Ones are surface, semi-flush, and convertible (surface/semi-flush) mount designs.
- Ring or ringless styles available
- Available in two styles for either QO?            or Homeline? interiors
- 100 A to 400 A Main Ampere ratings
- Available in 10 to 40 branch circuit space            configurations
          semi-flush
- Generator Kits available to provide switching            method between main utility service and back-up power source
- Can accommodate plug-on SURGEBREAKER™            Secondary Surge Arrester
- All units built per ANSI C12.7, NEMA PB-1,            UL standards 50, 67 and 414 and are listed in UL file number E-6294
- Devices meet Federal Specifications W-P-115C            for government housing
          Devices meet the Electric Utility Service Equipment Requirements Committee            (EUSERC) standards
- NOTE: Check with local utility to ensure selected            equipment meets local requirements
