joebell
- New Hampshire
I went on a service call yesterday for a 300 HP motor that had a malfunction. It seems that one of the terminations (split bolt connectors and rubber tape) had worn itself out against the cover and grounded out. I noticed all three split bolts were loose when I opened the tape. I should explain that this motor runs a peice of equipment at a recycling center and vibrates quite a bit.
I'm wondering if the split bolt connections are the proper termination or is there something else out there that I could use in its place, or were the split bolts not tightened correctly to begin with? Any and all sugestions are welcome.
Thanks
Thanks
