Ryanm00085
- New Jersey
I am installing a Reliance Controls PB30 generator box to power a panel from a 7000 watt generator. my debate is whether or not to use 10awg or 8awg wire. I know 10awg should be sufficient enough, but I feel like 8awg would keep any heat down. The run is only 50 feet, 35 inside which I will run romex and 15 feet outside, which I plan on using PVC and THHN with a junction box on the inside wall. I read the instructions and of course it says use either 10awg or 8awg. I just feel if the panel is drawing close to the max load, it would be better to use 8awg to cut back on the heat of the wire, but of course 10awg is cheaper and easier to work with. Any suggestions or ideas?
