30A receptacle with 20A circuit breaker
cpiper
I observed an existing installation with 30A 208V receptacles with 3/12 MC cable spliced to #10 THHN wire that runs back to the panel that lands on a 20A/2P breaker. A centrifuge is plugged into the receptacle and the nameplate data lists its ampacity at 20A. While this doesn't seem like a good design, is it Code compliant? Is there anywhere in the Code that says you can't have a 20A circuit connected to a 30A receptacle? Also, I believe the 20A circuit breaker would need to be 100% rated. Opinions?
Because the receptacle is rated 30A, do you think #10's should be used back to the panel? I'm concerned that someone in the future will not realize that the 30A receptacle is limited by a 20A branch circuit.
It's not required. What someone may or may not do there in the future isn't a concern of the NEC.
Well, the 3/12 MC cable is rated only 20A (per Southwire and Okonite). You could plug something into the 30A receptacle that exceeds the rating the wire. That would be hazardous, right?
I have to disagree. I don't think a 30 A receptacle is allowed on a 20 amp circuit per 210.21B2.
Steve
12 AWG copper MC has a rating of 25 amps at 60 C or 75 C. But the fact is there is a 20 amp breaker protecting it.
As far as the future no one should be up sizing breakers without having investigated the circuit the breaker supplies. :smile:
Make that 210.21(B)(3). (B)(2) is for two or more circuits.
After all a 20A breaker will probably hold 30 amps for a long time.
Steve
Recepacles.
After looking at the OP again, I'm not sure I'm disagreeing.
I intended to say a 30 A receptacle would not be permitted on a 20A circuit.
But now I think Infinity was saying he doesn't see a problem with the existing 20A receptacle and the spliced #10 wire. That does sound OK.
Recepacles.
A 30 amp single receptacle is permitted on a 20 amp circuit.
B3 also says for two or more receptacles, doesn't it.
Just when you think you understand something....
Doesn't sound like a good idea, but your right, the code does seem to permit it.
Steve
