chicago_sparky
If wires pull straight thru a junction box (no splices), do they still count as one conductor each, or all count as one conductor? For example would 6 #12's count as 13.50 or 2.25? Im having brain freeze...
chicago_sparky said:If wires pull straight thru a junction box (no splices), do they still count as one conductor each, or all count as one conductor? For example would 6 #12's count as 13.50 or 2.25? Im having brain freeze...
Correct. Now, if you were to create foot-long loops (i.e., 6" or more to each side of the center of the loop), you'd have to count them as two each (i.e., 27 cu.in.)Minuteman said:They would total 13.5 cubic inches.
LarryFine said:Correct. Now, if you were to create foot-long loops (i.e., 6" or more to each side of the center of the loop), you'd have to count them as two each (i.e., 27 cu.in.)
(B) (1) Conductor Fill Each conductor that originates outside the box and terminates or is spliced within the box shall be counted once, and each conductor that passes through the box without splice or termination shall be counted once. A looped, unbroken conductor not less than twice the minimum length required for free conductors in 300.14 shall be counted twice. The conductor fill shall be calculated using Table 314.16(B). A conductor, no part of which leaves the box, shall not be counted.
Roger
Minuteman said:Code reference please.
No, you didn't.roger said:Gee, Larry, we would have had to wait all that time for your answer. Surely we didn't steal your thunder did we.![]()
