sticko
- nothern virginia
I need help understanding ex.2 (a) and (b). I turn down an inspection because contractor was using EMT from a J-box to support another J-box to terminate and mount an exit light. The top box with the brach circuit was supported from the deck with an allthread and EMT conduit was supported with-in 36 inches. An EMT sleeve was attached to the blank plate from this box and was attached to the back of the fixture box. EMT compression fittings were used. Anywhoo, the contractor said he would replace the EMT with IMC or RMC. Ex#2 needs all conditions to be met. But I do not understand the verbage of (a) and (b). A little help?
