electricalist
- dallas tx
Just need some guidance.
330.10 uses permitted (11) wet locations.-b.a jacket resistant to moisture is provided under the metal covering.
Is this the plastic sheath between the wire and outer jacket? And realistically what is a wet location you would use it in.
330.30 ( d) 2 type mc cable fittings shall be permitted as a means of cable support.
Does this mean if its accessible ,no more than 6' with a type mc fitting at both ends, its considered secured and supported?
