334.10 MNC uses permitted
nascar03
Permitted use #3 states- other structures permitted to be of types III, IV, and V construction.... Cables shall be concealed within walls, floors, or ceilings that provide a thermal barrier of material that has at least a 15 minute finish rating i.e 1/2 sheetrock. However, 334.10(B) NMC shall be permitted as follows;(1) for both exposed and concealed work in dry, moist, damp, or corrosive locations, except as prohibited in 334.10(3).
This seems to contradic yes/no? explain
electrofelon said:
Fyi, Someome mentioned on this forum a while back that NMC is not currently manufactured by any of the major cable companies. Can anyone confirm?
Yes, it was mentioned. :D
electrofelon said:
So you are confirming that it was mentioned but not confirming that it is true? :wink:
That is correct. I can neither confirm nor deny the accuracy of the statement.
I can, however, confirm my inability to either confirm or deny the accuracy of the statement. :shock:
