electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
(C) In Unfinished Basements and Crawl Spaces. Where cable is run at angles with joists in unfinished basements and crawlspaces, it shall be permissible to secure cables not smaller than two 6 AWG or three 8 AWG conductors directly to the lower edges of the joists. Smaller cables shall be run either through bored holes in joists or on running boards. Nonmetallic sheathed cable installed on the wall of an unfinished basement shall be permitted to be installed in a listed conduit or tubing or shall be protected in accordance with 300.4.
If I go with the option in red, what exactly does that mean? Looking through 300.4 it doesnt seem like anything applies to surface mounting on a wall.
