sd4524
- Southern California
Last week I worked a job where i replaced all of the knob and tube wiring for a small house. (Thank You house flippers who made the "jumpers" from neutral to ground and reversed the polarity)
All of the new romex wire was run under the house in the crawl space. It is literally a belly crawl the entire time under the house. I would say the most room you ever had is 2 feet total. Some parts are smaller. Luckily I am a small guy and in pretty good shape. All of the wire gets stapled to the bottom of the floor joists. I can't even imagine dragging a hole hawg or corded drill under the house and drilling all of the floor joists.
Is a crawl space defined anywhere? Inspector passed this job no problems. I can't imagine the space under an old house here in SoCal being the same as East Coast basement or crawl space. If I ever have to drill these then i might need to look for a new line of work. Remember, I said the highest point under house is probably 2 feet.
What do you guys think?
