358.100
anbm
TX
Designer
Just noticed this from NEC - 2017
358.100 – EMT shall be made of one of the following:
(1) Steel with protective coatings.
EMT conduit usually does not have protective coatings? Thank you.
This is from Allied Tube:
[h=3]Features & Specifications[/h] Manufactured for Long Life
Allied Tube & Conduit® EMT is precision manufactured from high grade mild strip steel for exceptional durability and long-lasting life. Allied EMT is hot galvanized using a patented inline Flo-Coat® process. This process combines zinc, a conversion coating, and a clear organic polymer topcoat to form a triple layer of protection against corrosion and abrasion.
E-Z Pull® EMT combines strength with ductility, providing easy bending, cutting and joining while resisting flattening, kinking and splitting. Available in sizes 1/2 (16) – 4 (103).
