rojay
- Chicago,IL USA
Is it permissible to use the factory jumpers that were landed on the primary side of my single phase transformer? It seems to be set up from the factory in the exact configuration that is needed. Primary side is 240/480 volt- there is a factory jumper from H2 to H3 and the taps are from H1 to #2 and H4 to #7. Looks like the 480 volt primary that I need. On the secondary side X2 and X3 have a bonding strap between them - does it need to be removed and replaced with a wire? I need a 120/240 volt secondary, so I was going to leave the bond in place and add a lug for my neutral there. I find residential doorbell transformers a little easier to figure out
