Ravenvalor
- Piedmont region of NC
Hello,
A restaurant customer has 3 - dozen runs of conduit entering the floor from a big 15' long electrical panel. It is a floor to 7' tall type that houses the main breaker, all of the feeder breakers, all of the electrical panels plus all of the relays for the HVAC, hood fans and lighting. Some of the conduits are pulling air to the outside. On the other side of the wall of this panel is a biscuit making station. Over the past 23 - years a couple of pounds of flour has managed to get sucked into the electrical panel and it has coated the interior of the electrical panel significantly. Is it okay for me to block the outward draft of air by putting 3M - FB-FOAM inside each conduit. I could use the putty but the foam is much cheaper, quicker and seals better (at least temporarily, I know an inspector who does not allow the use of the foam for any electrical application. He thinks it is flammable and it is not UL listed for North Carolina).
Thanks for your help.
