Alwayslearningelec
- NJ
- Estimator
Is you have a 3P4W 480v panel feeding a xfrmr can you feed it with 3W on the primary side and 4W on the secondary side?
Yes, thanks. What does delta/wye exactly mean? Seen it referenced before with transformers. What causes no neutral on the primary side even if it's from a 4W source?That’s typically how it’s done, delta/wye.
No need for the neutral on the primary.
