enterprisenx
Hello
I need a 240V 3 phase source to supply a new motor. This is a specialty case for our site as all of our motors are 480V. Our electric supply is 480V B-Phase Ground (Corner Grounded) Delta. Let's assume I have to use a 230V 3 phase motor. If I buy a square d transformer like Square D 3T5F transformer, I am trying to understand if I need to ground my B phase on either side of the transformer or both. So the incoming lines are 480V - A, 0V - B, 480V - C, and the outgoing phases need to supply 240V only (hence delta). Does the B phase on the 240V secondary need to be grounded? The 480V primary side already has a grounded phase, but do I ground strap the H2 (B phase) terminal to the ground terminal? Wouldn't that potentially cause circulating ground currents by grounding again at at the primary side back to the MCC (origin of power source)?
Thanks for the feedback!
