3pole 20amp gfci circuit
Cubp
Texas
I have a customer that wants to add a 3 phase 20 amp circuit. Where he needs it is near a sink. I can't find a 3pole 20amp gfci breaker that works with the panel. Any suggestions.
Small sub-panel that will hold a GFCI?
(what panel do you have in already?)
It's a seimens QP. I don't like the situation but being that it's 3 phase 230v does it need to be gfci protected? It's a cord plug connected peice of equipment.
Doesn't someone make a dead-front GFCI device with an external donut for passing your own circuit wires through?
Specifically 210.8(B) only mandates GFCI for single phase:
(B) Other Than Dwelling Units.
All 125-volt through 250-volt receptacles supplied by single-phase branch circuits rated 150 volts or less to ground, 50 amperes or less, and all receptacles supplied by three-phase branch circuits rated 150 volts or less to ground, 100 amperes or less, installed in the locations specified in 210.8(B)(1) through (B)(12) shall have ground-fault circuit-interrupter protection for personnel.
Leviton makes one that is designed for use with a shunt trip breaker or I believe certain contactors. Its not listed only recognized.
Ok. So what Code is the OP on?? And keep in mind that things required by the 2020 haven't been invented yet.
-Hal
While I posted the quote from the 2020 code, the single-phase restriction has been there for a long time...
Here's the text that appears in the 2011, 2014, and 2017 codes:
All 125-volt, single-phase, 15- and 20-ampere receptacles installed in the locations specified in 210.8(B)(1) through (8) shall have ground-fault circuit-interrupter protection for personnel.
That is for Dwelling Units... I'm guessing if this is 3-phase, it is not residential... in which case NEC 2017 states... 1604605700748.png
