3R Loadcenter next to driveway
Doubleoh7
New member
Illinois
I am quoting a 200 amp service upgrade. The current loadcenter (Federal Pacific) is located in a kitchen cabinet. I decided that the most practical solution is to install a new loadcent (3R) on the outide wall. I see that a lot of guys out in Arizona do this.
Here is my dilema. The load center will be on the side of the house next to the driveway. There is about 3' between the house and driveway. The bottom of the loadcenter will be about 2' off the ground. Is there a problem with exposure to physical damage? I have been digging and can't find a code reference. There is no AHJ, I just want to do what's right.
Thanks
Thanks
"subject to physical damage" is not defined in the NEC.
If you are the AHJ then whether or not it is "subject to physical damage" is.....
up to you.:blink:
Is it prohibited to put a load center where it is subject to physical damage?
I think a good argument can be made that the direct physical proximity to vehicle traffic does indeed make it subject to damage from that traffic.
Having said that, how many millions of panelboards are located along aisleways with heavy forklift traffic? Or located on columns in warehouses with forklifts zooming by on a regular basis?
If it is a narrow passageway that the forklift regularly passes through anything you put there will be hit at some time. If there is a lot of room in the regular passageway it may seldom or never get hit.
