mstrlucky74
- NJ
Which is the more common way to wire a 3W? See two different pics. Thanks.
Commercial and most projects I bid are MC cable.Are you talking about residential or commercial and are you useing cable or conduit?
Method #2 may be easier if you are useing EMT or rigid conduit.
#1 is easier for NM or MC cable.
I think this was a Code change somewhere in either the 2008 or 2011 NEC. Neutrals are required at switch locationsWith the newish aforementioned code section requiring a neutral in the box, the op's #1 is the only code compliant way for resi - unless you use 14-4, but I'm guessing not many do that and instead just avoid dead ends.
