Bogiedown170
- Yonkers, NY, USA
Again, I’m new to this and not sure if there is any reference in NEC against running a 4/0 SER from ATS inside home from one corner of house to opposite side (approximately 80 feet) to where generator will be located. The interesting thing is that instead of digging a trench to run the SER and control wire, it was decided to run the SER and control wire inside the actual home along top of wall where a soffit would be built to cover the SER, control wire and gas pipe. Soffit will run along dining room, 2 closets and through a bedroom. There will be a section of SER that will run through small utility closet and under stairs with no soffit and then turn under stairs, back up to another closet where soffit will pick up the SER. The SER was strapped down every 30” with 2” clamps about 2 inches from ceiling along wall. Also, the control wire was tie wrapped to SER. Please help me understand if running SER like this inside home is acceptable and can wire control get tied wrapped to SER? If not correct, what are NEC reference codes? Thanks.
