4 11/16 with two gang device opening in back of box
JJWalecka
New England
Im looking for a 4 11/16 box with a two gang opening in the back, similar to the image provided except the image shows a single gang. I would appreciate it if you could provide a part number or point me in the right direction
What box does is this supposed to be put on? Is it in the wall or surface?
-Hal
I have a four square with a two gang plaster ring installed with sheet rock...I have to mount a box on top of it to surface mount a raceway. Spent about fifteen minutes trying to find a part number... haven't given up hope of finding it and hoped my peers could assist me
I've never seen one of those in a 2 gang version. Since the single gang 4 11/6 version is larger you could probably cut out the 2 gang cover in the existing 4" box, replace it with a single gang, and install the single gang 4 11/6 box over it.
If you turn it 90 degrees, you’ll see the 2 holes on the top and 2 on the bottom that fit a 2 gang screw hole pattern.
