A spec sheet for a transmitter has the following output data:
"4-20mA = 800ohm max, 12-Bit resolution, internal or external power"
Is this 800ohms refering to the input impedence with the transmitter will be connected to. In this case a PLC input?
Does the internal/external power mean this transmitter can be powered with a 24V loop power or an external power source?
