I am installing (4) 200 amp meter pak with (4) Tenant breakers, 1 phase 120/240 volt on a commercial bldg. According to local regulations if the load center is more than 6 Ft. from service panel you shall install a (4) feeder conductors with seperate neutral and grounding bus bars. I have sized the conductors at 3/0 copper (90deg C) 225 amp. 2 (3/0) ungrounded conductors, 1 (3/0) grounded conductor. Where in the code does it state what size the grouding conductor can be reduced.
