4" low voltage slope ceiling IC cans
bobbyho
With the holiday weekend I have supply houses to call about a 4" low voltage, slope ceiling IC rated can. I typically use Halo or Lightolier. Does anyone know if either of these companies make the 4" slope lv fixture? Or if there are other manufacturers such as Juno. Any suggestions would be great.
I've used Juno IC44 cans with an 444w-WH adjustable trim, but it will only work up to a certain roof pitch. I believe the trim will adjust up to 35?.
[edit] this is not a designed slope can, but the trim will allow the lamp to tilt down
