I know that Steel RMC is stronger then Aluminum. But does anyone think it will make a difference if Aluminum is used for mast that will go unsupported 36" above the roof-line ? The quad plex that will be attached will be around 50' from the pole.
Reason I ask is that for some reason, the supply house we use has the Aluminum 4" RMC cheaper then the steel. ?? Dont seem rite .. but I double checked and its correct.
Also . Can Steel thread-less Compression fittings be used for Aluminum RMC ? The RMC will need to be cut and we do not have the means to thread anything over 2 inches.
Thanks for you input
