Therealcrt
- Kansas City
- Electrician
Question: I installed a 4 socket meter can bolted together to a main disconnect for a townhouse. All the sub panels were ran underground in 2” conduit. I piped right up into the meter can all 4 conduits into the concentric knockouts. 1 of the concentric knockouts land right underneath the ground bar pan which can be removed to pull the wire into that conduit but the lowest meter socket assembly is also in the way which is a horrible design and the socket has torque marks on all the nuts and bolts which indicate I cannot remove it in order to pull the feeders in the conduit. Dumb dumb design but the question is can I remove that meter socket assembly to pull in the conductors or what? I have no other option
