I am reviewing a lightning protection system design. The drawing shows a 4" solder block section on the bonding conductor between grounding loop and steel column . I was told because the bonding conductor is stranded conductor that can get moisture through the slab. The 4" solder block section can block any moisture. Have you guys heard about it? Could you please tell me which code requires it? Thanks.
