I am not going to dig it around. Non-primary configuration not listed on the label itself requires research on your part as electronic ballasts..
No example part number means the original post was just BS? I have dis-assembled about 15 different electronic ballasts*, mostly the universal voltage type, and reverse engineered the circuit as part of some proprietary harmonic studies.
Every ballast I have tested and drawn out the internal schematic for will operate with any of the blue wires not connected. Overall efficiency of operating a 4 lamp ballast with only one lamp is however often less than with 3 or 4 lamps, but the overall power is almost proportionally less so there is less heat. The efficiency only drops due to some constant low loads that power a few mA of control circuitry.
* part numbers can be made available on request, but will require you sign a proprietary information agreement and have a corporate business arrangement with company ... or, you can consider the above all BS also <G>
