4 unit condo
mortimer
newengland
It seems that one can install the main service with all 4 of the discos at one end of the building.
And then run the SER through the other buildings to feed the now sub panels for each of the units.
Is this right, or am I missing something?
kwired
Electron manager
NE Nebraska
Is it a single building or is it multiple buildings?
Rated partitions can effectively make multiple buildings within a single structure - penetrations between those partitions can be an issue with building codes.
Vince1971
Eden, NC
If they are true condos then each tenant only owns whats inside the 4 walls & floor to ceiling. The attic space is common as well as the crawl space if applicable.
