rustynailhead
- ny
installing a 4 way to an existing 3 way. The feed and switch leg are at one location, so naturally the feed is sent to the far 3 way switch(white hot, black and red travelers). I put a j box in the middle cut the 3 wire between the 3 way hooked the white back together(keeping the hot at the far switch). I took two pieces of three wire to the new four way(not using the whites) and interupted the travlers using black and red...one set of wires(black and red) to one 3 way's travlers and black and red to the other three way's travelers, hooked them to the 4 way switch. For whatever reason I can not get it to function properly...am i missing something. Its a cooper 4 way....two black screws on the bottom and two gold on the top.. I am seriously baffled, i've hooked up many four ways and never had a problem...I must be over looking something, typically i would hook one set of travlers to the right side of the switch and one set to the left....i added an image to help, seems simple but i dunno, maybe im missing something
