sparkync
- North Carolina
I have a customer who I am going to be running a line from the "Main electrical panel" to a "generator inlet" box on the outside. I've noticed that the "50 amp inlet boxes" I see, don't have a "ground terminal screw", only a "ground jumper" to the box, mounted directly to the box, with no provision for another wire. I got to thinking that the "house ground" is already in place through the water pipes, and ground rods, then it seems I would only have to run a 3 conductor cable instead of a 4 conductor to the inlet box, since the generator would only be supplying the hots and neutral, since the "ground" is already available in the electrical panel. Am I thinking right according to Code? The run is going to be around 80ft., so I need to know if I'm thinking right, to save money on the wire. Normally, I would run 4 wires. I thought it strange the inlet boxes did not have a grounding lug available in the box. Thanks for the input.
