Hello,
Summary:
I'm new to this site and have been a licensed electrician for 5 years. I've done mainly residential with limited commercial work. I have a customer who I have done residential work for who owns a 2 unit commercial property that has 100 amps / 3 phase servicing each unit. One unit is a Deli and will remain as is... but the other unit is going to be leased to a Yogurt shop that has done load calcs and will require a 400 Amp / 3 phase service. The utility company says that it can bring only 3 phase 120/240 volts with High leg (stinger) to the building via underground.
Now my questions:
1.) Any suggestions on what products (square D, siemens...) would work best in this scenario?
2.) I'm assuming that the utility feed will go into a meter/can from which 500 kcmil will feed a load center? OR into a meter/can from which 2 - 200Amp breakers/disconnects will feed two separate 200 Amp load centers?
3.) Ground wire size? Ground rod?
I figure this will be a good learning experience, I just need to get going in the right direction.
Hope I haven't offended anyone with my lack of knowledge.
Any help will be greatly appreciated.
Thanks,
Ted
Summary:
Now my questions:
Thanks,
Ted
