Stevenfyeager
- United States, Indiana
- electrical contractor
IN/KY area, 400 amp meter base and 2 gang 200 amp (2 - 100 amp sockets) meter base. No one around here has these. Any suggestions ?
Don’t know about 2-100 amp, why you would use a 400 amp for that, but the cheapest 400 with two 200 is here;
RONK 400 amp single phase lever bypass meter Box With Dual 200 Amp Main Breakers | eBay
Find many great new & used options and get the best deals for RONK 400 amp single phase lever bypass meter Box With Dual 200 Amp Main Breakers at the best online prices at eBay! Free shipping for many products!www.ebay.com
This company has them in stock, got one a couple of weeks ago.Just tried to order one from my distributor last week. 20 week lead time.
no, now its $3100found a 400 amp (320) on line for $1600
Our poco will sell them to you, but they have been out of them for a long time. The engineer said they were having to go back to undeveloped subdivisions and pull the pad mounts to use elsewhere because they can’t get anymore.We are so lucky that the POCO here provides meter bases free, so we only need to supply panels.
Yeah, but he's $1300 more than my SH, if I want to wait 20 weeks. I really like the design of that Ronk. The aluminum cabinet makes it quite a bit lighter and it will never rust.This company has them in stock, got one a couple of weeks ago.
The thing I didn’t like about it, the ground lugs are only good for #2, and they are packed in too tight to change to a bigger lug. Also the breaker cover is held closed by two screws, so in order to access the breaker handle, you have to remove the screws. The customer didn’t want to pay more, but he didn’t have 20 weeks to wait before he built and moved into the new warehouse.Yeah, but he's $1300 more than my SH, if I want to wait 20 weeks. I really like the design of that Ronk. The aluminum cabinet makes it quite a bit lighter and it will never rust
I just looked at the spec sheet. It shows 2x 2 to 2/0 lugs for EGC. So one for the ground rod, and one for the ground conductor to the next panel. There's an additional 300kcmil out for the neutral.Th
The one I had, went up to only #2 for the EGC, I had to use a splicer/reducer to change to copper for the 1/0 EGC in the cable.I just looked at the spec sheet. It shows 2x 2 to 2/0 lugs for EGC. So one for the ground rod, and one for the ground conductor to the next panel. There's an additional 300kcmil out for the neutral.
The breaker door is secured with a standard locking tab, I don't see any screws.
